Display KHI Port Information
Use the following commands to display key health information about the types of control packets and protocols received on a port and sent to the control processor.
  1. In the Device Physical View, select a port.
  2. In the navigation pane, expand Configuration > Graph.
  3. Select Port.
  4. Select the CPP Stats tab.
CPP Stats Field Descriptions
Use the data in the following table to use the CPP Stats tab.
Name
Description
Port
Identifies the slot and port.
Packet
Shows the packet type.
PacketName
Shows the name of the packet.
RxPackets
Indicates the number of received packets on the port for the packet type.
TxPackets
Indicates the number of transmitted packets on the port for the packet type.
